Neck Reset Time..... Maybe (spelling corrected...)
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50237
Author:  Hesh [ Fri Jan 26, 2018 9:16 am ]
Post subject:  Neck Reset Time..... Maybe (spelling corrected...)
An imaginary OLF tub-o-lard aka Ov*tion Lube for the first one to guess incorporating the correct guess with a creative and hopefully funny guess if this guitar needs a neck reset and why or why not?
Employees of the OLF, Ann Arbor Guitars, Exxon Mobile (not really...) are exempt from participation. Offer imaginary and no actual OLF Lard of Ov*tion Lube will be transferred. Offer void where prohibited and only 1,000 guesses per individual.
TIA
(Thanks in advance not this is Africa)
Author:  A.Hix [ Fri Jan 26, 2018 9:25 am ]
Post subject:  Re: Neck Rest Time..... Maybe
Just lower the saddle a little... I dont see what the big deal is.. maybe cut the nut slots a little deeper..??
Author:  Colin North [ Fri Jan 26, 2018 9:33 am ]
Naw, it's just the action's set for slide.
Author:  jfmckenna [ Fri Jan 26, 2018 10:00 am ]
IT's just a bit too much relief.
Author:  Chris Pile [ Fri Jan 26, 2018 10:12 am ]
Catastrophic joint failure.... Almost looks surgical.
Author:  Alex Kleon [ Fri Jan 26, 2018 10:17 am ]
That's what happens when you remove the #13 1/2 fret. Just put the fret back in place, no reset required.
Alex
Author:  johnparchem [ Fri Jan 26, 2018 10:21 am ]
What is the Low action at the 12 fret?
Author:  Hesh [ Fri Jan 26, 2018 10:37 am ]
Hey John:
Action at the 12 of the high e is 4 75/64th" and the low e is 5 120/75ths" ;)
Author:  dofthesea [ Fri Jan 26, 2018 10:54 am ]
As the customer ...... this is only going to cost $50 right?
Author:  Clay S. [ Fri Jan 26, 2018 10:56 am ]
I've built a few similar, except the neck doesn't fold, it removes entirely and slips up the butt orifice. laughing6-hehe
Author:  Tim L [ Fri Jan 26, 2018 11:24 am ]
Should be able to adjust that with the truss rod. Just a little reverse hump.
Make sure the guy sits on it from the opposite side while you do the adjustment.
Author:  George L [ Fri Jan 26, 2018 11:31 am ]
This is what truss rods are for ... duh
Edit: Shucks, Tim beat me to it. laughing6-hehe
Author:  sdsollod [ Fri Jan 26, 2018 11:59 am ]
Is that one of those folding travel guitars?
Author:  J De Rocher [ Fri Jan 26, 2018 12:41 pm ]
Call it a harp and call it done.
Author:  fingerstyle1978 [ Fri Jan 26, 2018 1:14 pm ]
One of the few times that the words- "hold my beer...."
WORKED OUT PERFECTLY!!!! bliss [:Y:] laughing6-hehe
Author:  truckjohn [ Fri Jan 26, 2018 1:25 pm ]
Looks fine to me... What's the problem?
Author:  Hesh [ Fri Jan 26, 2018 2:20 pm ]
:D I had better not say what I was thinking since we don't have an R rated forum...:)
Nonetheless I have made that very same suggestion to a client or two through the years.....
Author:  meddlingfool [ Fri Jan 26, 2018 2:22 pm ]
Post subject:  Re: Neck Reset Time..... Maybe (spelling corrected...)
Looks like it's been 'travelized'.
Author:  Hesh [ Fri Jan 26, 2018 2:27 pm ]
Actually only $85 and it's ready for pickup, started it this AM and this is a clue/hint.:) See ya in a couple weeks David!
Author:  Hesh [ Fri Jan 26, 2018 2:30 pm ]
We have a weiner! Congratulations! It's a Travel-air folding guitar that is in for it's second set-up.... in a couple of years.
You can Google Travel-air and see a video of how the "Jesus Bolt" works and how you tuck the stings in the sound hole. It has a back pack case so it's easy to travel with when you get kicked out of your house for buying it....
Good job Steve your imaginary OLF tub-o-lard aka Ov*tion Lube is on the way :)
Author:  Hesh [ Fri Jan 26, 2018 2:33 pm ]
This was the second best guess simply because someone else beat you too. Good going Ed!
Author:  sdsollod [ Fri Jan 26, 2018 5:37 pm ]
bliss When I get that imaginary OLF tub-o-lard aka Ov*tion Lube I'm going to sell it on Ebay as a special lutherie accessory. Just trying to decide where to start the bidding... laughing6-hehe
Author:  John Lewis [ Fri Jan 26, 2018 10:19 pm ]
I was going to say don't bother with a neck reset, someone used it as a post hole digger, but I see it's one of those folding guitars. Yuck! I really hope the guy loves that thing and has a healthy sense of humor. At least it's not an Ovation. You are a good man Hesh!
Actually, as much as I want to make fun of the guitar, it is a pretty cool concept. And again, at least it's not an Ovation. ;)
Author:  Clay S. [ Sat Jan 27, 2018 8:06 am ]
"This was the second best guess simply because someone else beat you too. Good going Ed!"
Or possibly third - as I mentioned I build my travel guitars so the neck removes entirely and slips inside the body. Why waste all that interior air space and you can use a regular gigbag or a small suitcase to transport it.
Author:  ernie [ Sat Jan 27, 2018 9:00 am ]
Call the guitar doc this pup needs reconstructive surgery
